Catalytic Converted - FirebirdV6.com/CamaroV6.com Message Board
Catalytic Converted
  • Catalytic Converted
    So I just found out my cat went, and I wanted to see what cat people recommend buying. Please post a link of the cat you recommend.
    I was looking at getting this one from Grand Valley:
    gvperformance.com/store/index.php?act=viewProd&productId=93
    but most importantly what all will I need to do to install this and get it fitting right?
    Thank you,
    Bob
    Re: Catalytic Converted
    I have the same one in a 2.5, and i like it alot. to put it in you just have to cut out the old one and weld in the new one. I think you need a little piece of pipe because the old one is a little bit longer, also maybe a reducer (not 100% sure though) im not sure what size the old cat is. its not bad. good luck with it!
      pacesetter high flow cat. just need to get it welded in
      WAWA-A-HOLIC
        Thank you,
        Bob
        97RS4LIFE , Travis fom Grand Valley will give you a great deal so I would ask him about it when you order it.
          Or just gut your factory cat.
            Get the one you posted in the link.
              Didn't you JUST gut your stock cat?
                the one from gvp is cheap and a good buy. That is the one i will be going with shortly.
