Over heating - FirebirdV6.com/CamaroV6.com Message Board
Over heating
  • #16
    Re: Over heating
    ok thanks
    • #17
      Re: Over heating
      I hit about 220 degrees according to Scangauge. (+-)5 degrees during driving.
      • #18
        Re: Over heating
        cool i was just scared i was running hot but mine only hits 210 when sitting for a long time and usualy my temp during daily driveing is around 170-185
        • #19
          Re: Over heating
          you don't need a bigger pump. Our cars don't like running too cold. So you are right where you should be. elect. waterpump is if you are chasing every last HP for racing
          http://www.bowtiev6.com/
          • #20
            Re: Over heating
            well my car is doing great after my gasket change with the lower temps like 170-180 i can fell the power the whole time im in my car so im one happy guy
            • #21
              Re: Over heating
              plus before i couldnt churp 1st to 2nd when i drove for a wile because my engine got hot but now i can do it any time my heart desires
              • #22
                Re: Over heating
                That also depends on how hot your tires are, when cold they will chirp more than while hot.
                • #23
                  Re: Over heating
                  Originally posted by 3.8lcoty View Post
                  im sure this is not English class its more like texting a friend so i do not think i have to do everything perfect but thanks
                  Except only a handful of people can understand you. Instead of using your phone to get on a message board, use a computer, or get a better phone.
                  1995 Pontiac Firebird
                  • #24
                    Re: Over heating
                    uhh well thanks but i am pretty sure i use proper English i just do not use all the punctuation's that i should but like i said before this is not English class and i came on here for help not to be criticized by people who think they are English teachers.
                    • #25
                      Re: Over heating
                      I got no problem helping, but I simply can't understand what you're saying.....
                      • #26
                        Re: Over heating
                        i have said nothing that should be hard to understand so get off here if you not going to help me because i cant help you dont understand what im saying, i mean come on other people sure do understand what im asking.so if you dont understand just dont say anything.
                        • #27
                          Re: Over heating
                          but thanks for the help everything is going good and im getting a 170 drilled thermostat to keep down temps
                          • #28
                            Re: Over heating
                            Seems to me there's some misunderstanding about thermostats.
                            A 160, 170 or 180 'stat does not good if the system cannot cool down to that level.
                            The stock 4G V6 F-car radiator is a POS with a skinny little core. You can change the fan-ons via calibration, and that can help a little, but what you really need is a bigger radiator.
                            RockAuto.com sells a Spectra-Premium with a one-inch core vs. the stock 0.625 core. It makes a big difference. Couple that with lower fan-ons and you'll see a useful improvment. Plus, the Spectra-Premium costs less from Rockauto than an OE replacement ACDelco radiator. The Spectra drops right into the stock mounts.
                            For those making lots of power, even the Spectra will not be adequate. In that case, Fluidyne makes a light-weight, two-core all-aluminum radiator which really cools a ton. It's built the same way Fluidyne's NASCAR radiators are done. The Fluidyne, like the Spectra, is a drop-in fit.
                            I have a Fluidyne, a 180 'stat, lowered fan-on temps and straight water and Red Line Water Wetter for coolant and on the highway I see ECTs in the mid-170s to mid-180s. In traffic I might get up to 200 on the hottest days--in the desert southwest that means 105-110 degrees. On cooler days I can be in traffic and the fans don't run.
                            Ran the car on Westech's chassis dyno yesterday and the Fluidyne keep ECTs between 180 and 190 and allowed us to make dyno passes with minimal cooling off time between runs. That's important at 125 bucks an hour for the dyno time.
