Stage 8 bolts - FirebirdV6.com/CamaroV6.com Message Board
Stage 8 bolts
  • Stage 8 bolts
    I'm going to be doing plugs on my 3.8 bird. I've been thinking since I'm under the car I want to replace the nuts on the headers. Is there an advantage to stage 8?
    If there is, where I get these for my V6?
    Re: Stage 8 bolts
    Unless you have a reason to take off those nuts I wouldn't suggest doing it since you can run into more of a problem than you might want to deal with. Anyways, do a google search for "locking header bolts". The advantage is that they won't come loose because you usually have to retighten them after a drive or two.
    TEAM C6V6
      Re: Stage 8 bolts
      if you aren't replacing with headers, just leave them alone. No reason to switch out if you have stock manifolds on there yet. Just asking for headaches when you snap one of the studs off in the head
      http://www.bowtiev6.com/
        Re: Stage 8 bolts
        Summit Racing has them
          Re: Stage 8 bolts
          autozone will have some... also grade 8 bolts are not neccessary.... they are more for strength, not heating conditions.
            Re: Stage 8 bolts
            Stage 8 is a company that makes header bolts, as well as a number of other bolts. The OP was not meaning grade 8 bolts.
              Re: Stage 8 bolts
              I would'nt worry about them if you have pacesetters, I bought some but the header primarys are to small and dont come into contact with locks.
