I'm going to be doing plugs on my 3.8 bird. I've been thinking since I'm under the car I want to replace the nuts on the headers. Is there an advantage to stage 8?
Unless you have a reason to take off those nuts I wouldn't suggest doing it since you can run into more of a problem than you might want to deal with. Anyways, do a google search for "locking header bolts". The advantage is that they won't come loose because you usually have to retighten them after a drive or two.
if you aren't replacing with headers, just leave them alone. No reason to switch out if you have stock manifolds on there yet. Just asking for headaches when you snap one of the studs off in the head
