I change the Coolant from my 3.8V6 Camaro (2001) every 2 years, with GM Dexcool.
The only problem is, i can't getting it all out, still a few liters left.
Is there some plug on the underside of the engine, where i can drain the rest of it ?
do some one have a picture of this drain ?
Haynes says to unbolt a knock sensor on the side of the engine, I've never done it.
that, or a freeze plug.
but IMO its stupid, dexcool is suppose to last 100,000 miles, there is no reason leaving a little behind will be bad, not to mention if it is being replaced every 2 years
