Does anyone know where i can find a full length of over the axle piping? mine split right in the middle and its beyond welding :eek: would this work? its says for a 5.7L but doesnt say what diameter piping...i have 3.4l and my piping is 3"
Over the axle pipe
Perhaps if you have an exhaust shop near you, you could go there and see if they can order you one.
The shop I went to said they were ordering me one just like that, when I returned for the install they said that summit no longer sells them. But maybe that was only for the 3.8. Instead they saved me like $100 and created it out of hydraulic bent 3" tubes and said it was no problem since it wasn't harsh bends.
Sent from my SCH-I500 using Tapatalk
Re: Over the axle pipe
Originally posted by mousemonster1232 View PostPerhaps if you have an exhaust shop near you, you could go there and see if they can order you one.
You work at an exhaust shop? The one posted looks like it would work, but you would cut off the first bend, its going the wrong way. If you work at an exhaust shop give someone a twenty to bend your pipe and weld it in.Team NoVa
Originally posted by flamingchicken View PostYou work at an exhaust shop? The one posted looks like it would work, but you would cut off the first bend, its going the wrong way. If you work at an exhaust shop give someone a twenty to bend your pipe and weld it in.
i dont mind buying that length of pipe...its just the diameter im worried about...and if i buy that and its the wrong size...ill hear endless b*itchin to make modifications...
