Headers - FirebirdV6.com/CamaroV6.com Message Board
Headers
  • Headers
    Hey Guys,
    So just recently Ive been pondering the idea of buying headers for my car. However Im not sure whether paying a shop to order them and put them on for a grand total of $525 ( Brand are Pacesetter Headers Ive Heard negative reviews about them) Or purchasing CIA Headers for a total of $485 ( Just the Headers alone) What do you guys think?
    Re: Headers
    buy any headers and install them yourself not that hard. just a bit of knuckle busting. and cut the manifold from the exhaust. and have a shop well the y pipe.alot cheaper for me . there charging me 300 for my headers and 100 to do my exhaust.
      Re: Headers
      If you have 1-2 days, it's easy enough, no wiring to mess with aside from O2 sensors.
        Re: Headers
        FFF longtubes or ebay longtubes.
          Re: Headers
          Where have you found ebay long tubes for our cars? I looked and found none?
            Re: Headers
            There's nothing wrong with pacesetters I would just advise u buy better gaskets as I do agree the pacesetter's are garbage..if your concerned about the appearance then by all means buy the CIA stainless or even the pacesetters but I have the black painted mid length and they work fine the paint burnt off quickly but I could careless i'm interested in sound and performance. They do the job and you can get them for a little over 200 new. Long tubes dont provide much gain for a v6 so IMO they arent worth the extra dough..your call everyone is different on this just giving some experienced input.
              Re: Headers
              Personally, I'd have a shop do them, the old manifolds tend to rust onto the engine, and the bolt heads on mine snapped off and had to be drilled out. Glad I made it someone else's problem.
                Re: Headers
                It seems all right.
                  Re: Headers
                  Yea the bolts are a PIA, BUT, you can combat this by soaking the bolts the night before and the morning of with lubricant (WD40, etc.) and it should make the process a little less aggravating. Save urself some dough and at least attempt it it's good experience.
                    Re: Headers
                    Originally posted by syrus323 View Post
                    Hey Guys,
                    The last set of headers that I ordered were made by Hooker in the 80s,and I installed them myself on my 68 bird,losing the motor mounts to make room to work with a floor jack with wood block on the jack arm under engine for lift, the hardest part of the install was removing the existing exhaust manifolds, we had to use penetrating oil on the manifold bolts[overnight soak] and plenty of heat .Saved $300 on labor back then.:stp:
                    -JIMFIRE
