so im getting some pacesetter headers int he coming weeks, i just had a few questions before i install them. so i think im going with felpro gaskets and im going to replace the header bolts with some grade8 bolts. my questions are where can i get a egr gasket, should i get the copper gasket maker or spray, and should they be used on egr, header gasket, and the the ball flanges? also what clamps should i use to connect the y-pipe to the stock cat pipe, i dont plan on taking to the shop to get it welded. thanks guys
header questions before install
Re: header questions before install
I couldn't find a gasket for the egr tube so I got a sheet of gasket material and made my own. A lot of people will recomend the copper spray but I havnt used it and have no problems. As for the ball flanges I don't know what to do, I have an exhaust leak there that I might use some copper rtv on to try and fix it.1997 Chevrolet Camaro
L26, Pacesetter headers, SLP cai, Centerforce DF clutch, Pro 5.0 shifter, UMI short stick, 1le driveline, J&M 35mm front swaybar, UMI lca's/phb/sfc's, KYB AGX shocks, Hotchkis stb.
