egr block off - FirebirdV6.com/CamaroV6.com Message Board
egr block off
  • egr block off
    Hey guys, I have an exhaust leak coming from the header side of my egr. The tube is fine, but the piece that bolts to my header is bent and it keeps burning through gaskets. I'm in the process of making some block off plates out of 1/8" steel, and I was wondering if I should put a gasket under the plates or if copper rtv would be good enough. Also what's to keep them from shifting in the future and causing leaks? Would the 1 bolt per plate be enough to hold them? Thanks guys.
    1997 Chevrolet Camaro
    Re: egr block off
    Those of you who deleted your egr, where did you mount your dip stick?
      Re: egr block off
      Same place just used a zip tie to the bolt at the head stud.
        Re: egr block off
        Yeah that's what I ended up doing. I used a piece of electric fence wire and wrapped it around the tube twice then each end around the stud and threaded the nut back on it. I've got it all done, I just want to wait till the rtv is dry before I start her up.
          Re: egr block off
          That should hold it.
            Re: egr block off
            does your dip stick tube ever pull out of the hole when you check your oil? I need to find a way to secure mine in the block, I keep forgetting to hold it in place when I check my oil.
              Re: egr block off
              Doesn't egr need to be tuned out anyway?
                Re: egr block off
                I swap a broken egr (base and tube) to a used one, but didn't have the hole to screw the dip stick black tube. So, I just hold it to the black handle of the engine with a door spring. It have been working great for about three years, and it look nice to me. If you still have the egr valve base, it'll work for you, if not it help you some, I think.
                Camaro99\'3.8, original spoil package (no body mods...PROUDLY), K&N, Lid 3800II, SLP CAI, Flowmaster, Z28Chrome Tips, 180* Thermostat.
                  Re: egr block off
                  I took care of it with some jb weld. Went to check my oil after I wrote my last post on this topic and I could see the bottom of my dipstick as I was looking down toward the starter. The tube was out of the hole it goes in in the block.
