I installed a cold air kit on my 01 camaro 3.8. I noticed that since I don't have fog lights, the cutout would be perfect for true cold air. Has anyone put the filter close if on opening?? I didn't know if it would conterreact itself being the pipe would be rather long?? Any feedback would be appreciated
air intake thoughts??
Re: air intake thoughts??
It's more of a generic cold air, just has two chrome pipes, 2.5" to 3" in diam. Couple elbows and reusable filter. I got it off ebay for about 50 bucks. I'm impressed with the sound and pep it gave. The way I ran it is one pipe runs towards driver side, on top radiator, I then ran the pipe downtown where it drops behind the bumper. I think I may try to figure out a pipe I can run from behind the foglight opening, which I don't have foglight, to try to force more air to the filter.
I was thinking about a different intake ever since I first did a filter change. I am stunned at the routing to the filter box and how ineffecient it seems. I removed the connector pipe from the filter box to the light duct. The pre 98's have the intake routed from behind the headlight on the driver side if i'm picturing it correctly (I've wondered if this provides a small ram effect on its own). I was considering getting one of those ebay cai's as they seem to not have that narrow point near the brake lines and putting it down in front of the headlight and blocking off the space to the engine bay to keep the cooler air going in. There is a plastic panel protecting it from the underside so the only way I see that it would take in water would be if you were seriously tailgating someone in the rain who sprayed you from a big puddle. The wheel is behind this point on the car so you're not gong to splash yourself.96 White M5 Camaro. Manual everything. Magnaflow cat, dynomax dual outlet axle back. Swapped to a disc rear with 3.42s and a torsen differential, kyb gr2 rear shocks, moog rear endlinks.
