Recently purchased a resistor that replaces the AIT sensor. Read on several sites about the restrictions of the factory aircleaner/induction tube and seemingly the only replacement is hard to find. Though I'm still testing the fuel eficient properties (resistor), so far have noticed some gains in low end torque and the iddle not dropping to low when I initialize coasting. To the point, the factory air cleaner could be replaced with no further modification or pricey system. So I installed a 4'' conical air filter and so far have not pissed off the computer. Also didn't notice any additional noise from the open air element but some additional throttle response, nothing to bragg about but overall performance seems better. Also have an open flow muffler w/dual 2.5 pipes.
conical air cleaner
I'm not sure where you're heading. You used a resistor to trick the computer into thinking its getting more cold air? That's really all the power programmers work. It might give you a couple HP but at the expense of fuel efficiency and running rich. Assuming you also have a 98/99+ 3.8? The air silencers are restrictive and I was looking for tubing and couplers to delete it but couldn't do it with a stock lid. I'm picking up a whisper lid soon and that'll get it done on top of current SLP cai duct and a k&n filter
Re: conical air cleaner
i think the iat resistors tell it that its getting cooler air. so it doesn't pull timing, and won't add extra fuel for cooling purposes. i'd rather have the extra knock protection myself. most of the sound from intakes comes from the tubing. the deeper sound you get anyways.
Those resistors can backfire on you also, I tried one many years ago and it kept my A/C from working right.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Yes, 3800 II,5-spd. It wasn't my intention to remove anything at first. I was and am looking to improve the fuel economy, air in and air out have always been the best ways to improve engine efeciency and power which equates to economy. These computer engines are new to me but I have heard for many years of plug-in devices that give them beter HP and economy. Unfortunately my car doesn't get anywhere near what the EPA estimates were (25-30mpg) , I drive like pawpaw and only get @18-20mpg. I have spent less than $100 for all the "upgrades" combined and kept all my stock parts. That could have been two more fill ups and so far no noticeable increase in fuel economy. If you guys know of any deffinates for improving the fuel efeciency on these cars I'd really appreciate the heads-up. Just thought the method I used could help anyone looking to replace the stock induction system.
Originally posted by tiller83 View PostYes, 3800 II,5-spd. It wasn't my intention to remove anything at first. I was and am looking to improve the fuel economy, air in and air out have always been the best ways to improve engine efeciency and power which equates to economy. These computer engines are new to me but I have heard for many years of plug-in devices that give them beter HP and economy. Unfortunately my car doesn't get anywhere near what the EPA estimates were (25-30mpg) , I drive like pawpaw and only get @18-20mpg. I have spent less than $100 for all the "upgrades" combined and kept all my stock parts. That could have been two more fill ups and so far no noticeable increase in fuel economy. If you guys know of any deffinates for improving the fuel efeciency on these cars I'd really appreciate the heads-up. Just thought the method I used could help anyone looking to replace the stock induction system.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Cheap intake mods, keep the factory air box, delete the silencer, make sure you keep it clean, I run seafoam regularly. Got 3" exhaust with no cat, and an o2 simulator in the rear sensor, T5, 148k miles, and 4.10s, I get ~25 average. No gas gauge because I'm too lazy to pull the pump for the sending unit, so I have to watch miles pretty close.
Also, that was the worst grammar in history.
Originally posted by thebeewantsboost View Posti get 17 in town 27 highway, pre and post turbo. i would do basic tune up stuff if you haven't.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Best to check the basics before buying things to trick the computer. If your car isn't getting the mileage it should, you should try to address the small things to see if anything is wrong. When was the last time the plugs were changed? Wires? How old are the coil packs? How often do you check the tire pressure and what do you keep it at? What kind of environment do you drive in, etc. So many factors to check.'99 Camaro
'04 Saab 9-3 Aero
'90 Audi Coupe Quattro
18-20mpg is in town. Aparently my wife gets the same in her maxima using premium and a smaller displacement, so maybe it's not that bad. Also my gas guage was crooked, took the inst pannel out (easy), cleaned the dust out and straightened the indicator. Originaly would only go as far as F and fill-up from E was only @12 gallons. So apparently I've always had more gas to run on and hopefuly will give me more accurate (beter) MPG stats. Went back to stock induction to keep out any gremlins.
Any model year with a stock aluminum drive shaft that's interchangeable ?
Originally posted by Ibanezz View PostI'm not sure where you're heading. You used a resistor to trick the computer into thinking its getting more cold air? That's really all the power programmers work. It might give you a couple HP but at the expense of fuel efficiency and running rich. Assuming you also have a 98/99+ 3.8? The air silencers are restrictive and I was looking for tubing and couplers to delete it but couldn't do it with a stock lid. I'm picking up a whisper lid soon and that'll get it done on top of current SLP cai duct and a k&n filter
The only extra work I had to do (aside from slightly shaping the aluminum tubing to match the airbox lid) to use the Grand Prix bellow was to trim the flange that butts against the throttle body so I could use the factory hose clamp. It does have an extra IAT sensor bung now, but if you can find something to plug the hole with, it's no big deal.
Right now I'm looking into getting some silicone intake tube connectors and a new piece of aluminum tubing to use in place of the factory bellows. Once the weather gets warmer so I can get out and do some measuring, I should be able to order what I need.
