Okay so the pace setters are on order and supposed to arrive tuesday. However, I dont know which wires to use so I bought the Accel 8 mm wires. Anyone know which wires to use with the headers?
Ignition wires with pace setters?
Re: Ignition wires with pace setters?
You can use 90 degree or straight boot, I use straight boot with boot protectors and they work great.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostYou can use 90 degree or straight boot, I use straight boot with boot protectors and they work great.
On a separate note, I am trying out the E3 diamond fire plugs for the car.
I have just cheap-o plug wires. Straight boot, no protectors. I burned through a wire once on the headers, but then I went through the garage and just mixed and matched lengths I had lying around until everything was routed well clear of any heat. Just have to play with it :P
I use straight boots with my pacesetters but I would recommend boot protectors, I'm running 10.2 mm wires.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I used 90* on my engine with headers
