Question about o2 sensors - FirebirdV6.com/CamaroV6.com Message Board
  • Question about o2 sensors
    The car in question is a 2001 Camaro 3.8.
    A few years ago, my catalytic converter clogged up, so I removed it and put in s pipe. I also put an emulator on the o2 sensor so I don't have a code.
    Now I decided to put on a catalytic converter and I had to replace an upstream o2 sensor on the driver's side, was getting a code. How many sensors is the car supposed to have?
    I see that I have 2 in the manifolds upstream ones and then right before the catalytic converter there is a bung with a nut in it. After the catalytic converter, there is a sensor there which is not plugged in and I have that plug up by the trans with an emulator on it. I am supposing it is for this post cat sensor. Is the car supposed to have a sensor rIght before the catalytic converter? There is a nut there in the bung and there is no plug available for it..I'm really confused..there was never a code though and I don't have a sensor there.
    Here are some photos..any help is appreciated.
    [Click image for larger version
ID:	1538997ATTACH]5573[/ATTACH]Click image for larger version
    Sent from my iPhone using Tapatalk
      Re: Question about o2 sensors
      It should have 1 before and 1 after the cat.
        Mine does not have it. All I have is 2 in the manifolds and one after cat. Works fine, no SES light.
          only the 95-98 have the pre and post cat senors
            What has happened now is the following..
            I had no SES light but I used a scanner and I got three codes p0137, p1133 and p1153..
            Apparently there is some kind of a problem with all 3 sensors now..so the driver's side manifold is a new Bosch sensor and the post cat is a new Bosch sensor..I called the dealer and they confirmed that 97-02 V6 Camaros had 3 sensors, 2 in manifold and 1 post cat.
            What could be the problem now? Could it be because I have Pacesetter headers? I am getting horrible gas mileage..
              did you get new painted pacesetter? if so there burning the inside coating off and killing the senors, once thats done then buy new ones.
