The car in question is a 2001 Camaro 3.8.
A few years ago, my catalytic converter clogged up, so I removed it and put in s pipe. I also put an emulator on the o2 sensor so I don't have a code.
Now I decided to put on a catalytic converter and I had to replace an upstream o2 sensor on the driver's side, was getting a code. How many sensors is the car supposed to have?
I see that I have 2 in the manifolds upstream ones and then right before the catalytic converter there is a bung with a nut in it. After the catalytic converter, there is a sensor there which is not plugged in and I have that plug up by the trans with an emulator on it. I am supposing it is for this post cat sensor. Is the car supposed to have a sensor rIght before the catalytic converter? There is a nut there in the bung and there is no plug available for it..I'm really confused..there was never a code though and I don't have a sensor there.
