Anyone ever take any data on the intake manifold vacuum on a 95-98? Maybe at the EVAP nipple on the TB?
Intake Manifold Pressure
RavenTags: None
Mine runs -16 to -18 vac. With the VS cam , dont run it off the TB, I think its off the map sensor. Don't remember the stock cam, maybe -20 to -22 vac.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Are you looking for manual numbers or readings off the map sensor? I probably have some stock logs lying around I can check.
I'm looking to see if anyone ever took a vacuum reading at the EVAP nipple on the side of the TB. [only applies to 95-98]Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Originally posted by FirebirdGT View PostI'm looking to see if anyone ever took a vacuum reading at the EVAP nipple on the side of the TB. [only applies to 95-98]08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I just want to compare my reading to someone else has taken the EXACTLY same reading. When I'm done with the Mod - I'll tell what I've done. :)Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
