Catalytic converter support bracket. - FirebirdV6.com/CamaroV6.com Message Board
  • Catalytic converter support bracket.
    Anyone happen to know the part # or have the metal support bracket that the catalytic converter uses? Has two bolts and a flat piece of metal that runs through a rubber bushing?. I got one from the junkyard but I'm guessing it must be year specific cause the one I got says v6, but does not line up properly.
    Mine a 2000 Camaro.
    1990 Firebird 3.1 T-Tops<br />Flowmaster exhaust<br />Kenwood MP 825 Deck<br />4\" Rockfords w/ tweet in dash plate<br />3 Way 6x9 Rockords in rear sails<br />1970 Camaro 350
    I am not sure what you are looking for? If it is a metal hanger can you exhaust guy not just weld in a new piece of steel that runs to the bushing?
    If it is the bushing, are you looking for this? https://www.rockauto.com/en/moreinfo...7hzvB5WQ%3D%3D
      Yeah a exhaust shop should be able to make another hanger if that’s what you need.
        Mine a 2000 Camaro.
        96-02 GM p/n 10289505 - this is the part that bolts to the cat - what year car did you get it off of - a 93-95 3.4 is p/n 10267393
        Raven
          I think I may have found the right one off another Camaro, I just need to go see if it lines up right, but for those who didn't know what I was talking about, it was this bracket.
          Click image for larger version  Name:	cathanger.jpg Size:	38.9 KB ID:	1576005
            Ahh gotchya- I still think your exhaust guy should be able to fabricate a work around for that piece fairly easily vs spending a ton of money. But glad you found the part!
