MAFT+ dyno tuning results are good. - FirebirdV6.com/CamaroV6.com Message Board
  • MAFT+ dyno tuning results are good.
    I didn't have a wideband to use, so the fuel numbers are conservative. We plugged in autotap the night before and went for a spin...94 octane...and with 6% lean we saw the O2 voltages hitting low .800s so we didn't go any leaner.
    Dyno results...
    6% lean and adv 4 deg of timing got me 8rwhp and 12rwtq.
    4% lean and adv 6 deg of timing got me 9rwhp and 11rwtq.
    0% lean and adv 8 deg of timing got me 9rwhp and 4rwtq.
    All the timing numbers came from the practice of advancing until the numbers stopped increasing and backing off one.
    I probably could go 8% lean without problems but don't want to risk it without the wideband.
    Very interesting results. This is on an n/a car.
    Next weekend i'll take these results to the track to see if they equal a 10th or what.
    One question... should I add octane boost and try advancing the timing another 2 deg at the track?
    1997 silver Camaro RS<br />|T-Type Powered|<br /><a href=\"http://www.kwfbody.com\" target=\"_blank\">Looking for a local F-Body club in K/W, Ontario, Canada?</a>
    Glad it's working out for. Those are respectible gains for a bolt on car.
    I wouldn't use octane booster it doesn't work properly like you would expect it to. Possibly run race gas if your track sells it, that will give you a LOT more room to play with advance.
    Also were you looking at your knock retard?
    Thats the other thing you're going to want to keep to a minimum if any at all.
      Yeah... we stopped with timing as we started to see knock. I was hoping to advance more than 4degrees but the knock started.
