im starting to install my pacesetter headers tomorrow. someone posted a complete install guide a few months ago and i was looking for it......if anyone know the link or has it please post it up. and yes i did search.
Starting header install tomorrow!
www.turbov6camaro.com/header.html [img]graemlins/wavey.gif[/img]www.turbov6camaro.com
1997 3800 Series II Camaro
i actually started tonight but im having problems getting to the header bolts....any tips??2001 Black Camaro<br /><br /><br />I have no clue how i beat you.....maybe your car is slow.<br /><br />Whisper lid, SSRA, Pacesetter Headers, Carsound 3\" Cat, SLP Loudmouth, BMR strut brace, black ZR-1 rims, Xenon kit
Originally posted by camarov62003:
i actually started tonight but im having problems getting to the header bolts....any tips??www.turbov6camaro.com
Offset wrenches are your friend when installing headers. I also used some long bolts, cut the heads off(approx 2" long) in the first and last holes, smaller than the actual holes so you can just pull them out.
This way I could apply some Ultra Copper high temp RTV to both sides of the gaskets, slip them over the cutoff bolts and press them to the heads. Then slip the headers over the cutoff bolts and get the threads started on the header bolts. Dont tighten them down completely until all the bolts are threaded and hand tightened, and work from the center out. This makes for a very clean install. Also make sure the RTV has had a couple minutes to "scale" up as it says on the directions, and dont crank down on the header bolts initially, just snug them up.
Then continue installing the Y-pipe and what not. After thats done start the engine, let it idle for a about a minute or so, turn it off let it cool and retighten the header bolts.
Hope that helps some.....
Here are the offset wrenches I was refering to.
http://www.sears.com/sr/javasr/produ...id=00944367000
Shane00 Pewter Y87 Camaro-SS Hood/Chrome rims, Black Halos, Clear corners, Pacesetters, V8 K&N FIPK, 3\" B&B TriFlow, HPP3, MSD Coils, Taylor wires, Transgo stage II, Edge 3000 Stall, 180* thermo, SLP Bowtie Grill<br /><a href=\"http://www.cardomain.com/memberpage/468763/1/\" target=\"_blank\">Carro</a>
