Exhaust Leak Sound? - FirebirdV6.com/CamaroV6.com Message Board
Exhaust Leak Sound?
  • Exhaust Leak Sound?
    What exactly does an exhaust leak sound like?
    2002 Silver Metallic A4 Firebird - All Options
    Hotchkis STB, Custom Madrel Bent 3" Exhaust, Pacesetter Headers, Whisper Lid, FT Ram Air, K&N Air Filter, D2S HID, Baer Rotors, !EGR, !MAF, 10% tint, Parrot CK3300
    Your Mom or My Dad?
    horrible.
    96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
      if you are accelerating really hard it sounds like your motor is stumbling. its like a really high pressure blast of air coming from your engine compartment. and yes it does sound really bad
      1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
        I had my clamped on cat leak awhile back. It just sounded like a rough edge to the exhaust at times that didn't need to be there. You'll know if its leaking because it will be a tone that doesn't sound like your exhaust. Was a little harder to notice when I had no exhaust on the car and my headers were leaking but if you pay enough attention you can hear it (warning u may start hearing random noises you never noticed lol some are normal, have to learn to tell the diference) My leak was a ticking in the driver side and alot more noise then should be coming from the center console under load (minus the ticking for my leaking cat).
        00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
