SLP IAT SENSOR - FirebirdV6.com/CamaroV6.com Message Board
SLP IAT SENSOR
  • SLP IAT SENSOR
    OK my question is, where on the stock air box does this thing plug into, and will it work if you have a cai system already installed? BTW I know that it is supposed to loop your a/c system to make the computer think you don't have air and it is said to give an extra 5 hp. I just wanted your input before I buy it.
    You are lucky if you see even 1 HP from this mod.
    Check the reviews forum, there is a write-up about this piece of garbage.
    If you want to get a better IAT reading, pop the sensor out of the hole in the air-box, extend the wires, and put them right at the beginning of your airbox so the air is still cooler.
    http://www.camarov6.com/ubb/ultimate...;f=29;t=000007
    \'97 Camaro: GN Turbo w/intercooler, 3.42s w/ Auburn HD posi, Bulletproof 4L60E-HD, stage II shift kit, Vette servo, MSD Ign, K&N, Ported TB/MAF, 3\" FlowMaster, 160* thermo, HPTuners v1.6
      Yea, I havent heard good things about it either. Honestly i wouldn't bother, you can just save the money and do it yourself if you really want it. If you already have it, it probably plugs into that socket on the right side toward the top of the box. Theres already a wire there but im sure you remove it. I'm not sure about this, just my guess.
      \'02 W68 Pewter Metallic Firebird-RKSport Headers, Catco 3\" cat, SLP Loudmouth, Fast Toys ram air, K&N, !Air Silencer, shaved airbox lid, SLP fan switch, BMR strut tower brace
        waste of money
        2000 3.8 A4 Pewter Camaro
          Thanks guys. That is why I post here.
