Really stupid question...but where can i remove my factory exhaust from without having to cut it? Cause i rolled under and after the y pipe is the cat and after that is the sensor, and then there is a clap and then it goes all the way back...am i not seeing something? Like is it heald together by that clamp? Or is there no way to take off the factory exhaust without cutting? Sorry for the stupid question. Please answer ASAP cause i would like to take this off today.
Removing factory exhaust
There is only the one clamp under that suport rail, the exhaust was installed by GM before the rear axle.
You will probibly have to drop the axle somwhat if you wanted to do that.~chris~ 98 Cayenne red Camaro 3800 A4, 3:08, T tops Borla cat-back, wisper lid K&N, Bilstine shocks, Dunlops all around. <br />AOL IM: chevyboyz24
I need to drop my axel in order to unbolt my exhaust?2002 M5 camaro- VTR CAI, custom cat-back exhaust, battery compacitor, pullie, lowering springs, 32mm sway bar, cross-drilled slotted rotars. 1-10\" L7 in cubby.
the only way to take off your stock exhaust without cutting it is dropping the axle. if you don't drop the axle you would have to cut the stock exhaust.2000 pewter firebird<br />Short Throw Shifter, Whisper Lid, Whisper Ram Air, Holley Filter, B&B Triflo, LSD, BMR LCA, STB, PHR, and sway bars (32/21).<br />Power window conversion
How exactly will i drop the axel? What tools are needed? Do i need to decompress the rear springs or anyting like that? Thankyou.2002 M5 camaro- VTR CAI, custom cat-back exhaust, battery compacitor, pullie, lowering springs, 32mm sway bar, cross-drilled slotted rotars. 1-10\" L7 in cubby.
You'll want to cut it! [img]smile.gif[/img] No sense dropping the axle for just the exhaust, btu that's just me. You'd have to really be lifting the body, then disconnect the shocks, etc, to drop it. Not something (at all) you could easily do in a garage at home with a cheesy jack and stands, particulary if you don't want to disconnect brake lines, etc.
Are you installing a new exhaust? Go to a nice performance shop, they should weld it up for you for around $40 or so.<b>97 Camaro 3.8L M5</b><br />Car for sale<a href=\"http://terpmotors.com\" target=\"_blank\">terpmotors.com</a> Terrapin Motorsports! UMCP
When I removed my exhaust, I backed the car up on ramps and just unbolted one side of one cross member. I can't remember which one exactly, but you DO NOT need to drop the axle to remove the exhaust in 1 piece.<a href=\"http://www.cardomain.com/id/sac2165\" target=\"_blank\"> CAMAROS</a>
