I have a 97 camaro, and I need to remove the air silencer and stupid pinched hose between the TB and my chrome intake. There is a picture of it Here.
Any help is appreciated. Thanks alot
You mean you want to know how to replace it? If so, I trashed my stock setup and made my own intake. I went with 3" PVC, and used a propane torch to heat the PVC up enough to make it bendable, then put it in a vice to make the bends so it would fit in the small space. Pic 1 Pic 2
