I'm not sure if this is the right forum but I believe it's related to my intake lid. A while back I tried removing the air silencer on my own, well that failed misserably and a SES light appeared. Had it read and it said the idler valve has been dissabled by the PCM. So I got my real lid and eventually replaced the Idler valve. I disconnected the battery for an hour or two to clear the codes. Start up my car and no light, but a little while later it's back. Is this a known problem with whisper lids? What can I do to solve this problem?
SES light won't go away
1998 Red RS 3.8l A4<br /> Whisper - K&N - N20 - 1LE Panhard - Ghetto STB - 255/50ZR16 Ecsta<br /> Removed grille - Limo tint - blackouts - A-pillar cf a/f ratio<br /> Panasonic DF88 - 1 12\" Eclipse 88120.4 - Eclipse 3322 amp<p><a href=\"http://members.cardomain.com/raven_rs\" target=\"_blank\">http://members.cardomain.com/raven_rs</a>Tags: None
by just disconnecting the batt won't resent the pcm not on the obdII, now some say that if you pull some fuses and the like turn the key on, not starting it, that that will reset the pcm, but my bud that is a good mechanic, or at least i think he is, he says that the obdII's will still store the code in the memory for emissions purposes.
do a search on how to reset the pcm, i can't remember the steps for y a1997 Firebird Convertable White, with custom Purple pin striping and custom Purple detailing!!!<br />Y87 Performance Package W68 Apperance Package<br />Boydes, aluminum rims 16\" BMR STB <br />SLP Cold Air Intake 3\"hiflow cat 3\" dynomax custom catback, 2.5\" Flowmaster 80. Slp Take off Shocks, Springs And Struts. Transgo shift kit with corvette servo!<br />Sony Explode CD Player Kicker Comp VR 12, and Explode 760Watt amp!!!<br />5% Tint on the side windows, Correction officially 2% on the side windows, or at least that is what the highpo said and 15% on my rear window<br />Yup Purdy Car!!
go to www.installuniversity.com and somewhere on there it will tell you how to rid your car of the light.2000 NBM M6 Camaro Z28<br />323/335
Yeah I found that in my search for SES codes with lids so I gave it a try. Turned my ignition pulled the fuses and let it sit for at least 15 minutes. Code was gone for a little while but came back.1998 Red RS 3.8l A4<br /> Whisper - K&N - N20 - 1LE Panhard - Ghetto STB - 255/50ZR16 Ecsta<br /> Removed grille - Limo tint - blackouts - A-pillar cf a/f ratio<br /> Panasonic DF88 - 1 12\" Eclipse 88120.4 - Eclipse 3322 amp<p><a href=\"http://members.cardomain.com/raven_rs\" target=\"_blank\">http://members.cardomain.com/raven_rs</a>
If it means anything I had the code scanned agian at autozone today (was having a missfire in #6, spark plug cable fell off :mad: ) But the code is P1652. IAC valve has been reset by PSP, failed On. Or something along those lines. I'm thinkin this might be something I'll have to take to the dealership if no one here knows what to do.1998 Red RS 3.8l A4<br /> Whisper - K&N - N20 - 1LE Panhard - Ghetto STB - 255/50ZR16 Ecsta<br /> Removed grille - Limo tint - blackouts - A-pillar cf a/f ratio<br /> Panasonic DF88 - 1 12\" Eclipse 88120.4 - Eclipse 3322 amp<p><a href=\"http://members.cardomain.com/raven_rs\" target=\"_blank\">http://members.cardomain.com/raven_rs</a>
