Custom intake - FirebirdV6.com/CamaroV6.com Message Board
Custom intake
  • Custom intake
    I have an 02 v6 firebird and was searching around for an affordable intake. Found one on ebay fairly cheap but for the wrong year. They offered to make a custom one for me but required these measurements. Can anyone kindly help?
    "The gap in between the throttle body to the back of the maf sensor"
    "The length after the maf sensor till the oem air box.
    also the iat sensor location"
    I know little about engines to be honest, and this is the first car to really inspire me to at least try to learn. If anyone could give me those measurements I would very much appreciate it.
    01 V6 Firebird, Flowmaster catback, Navmate gps, B&M Ripper.
    You could make your own for cheaper probably. Do a search for a home made intake, or just ask some of the 3.8 guys around, they'll give you some good ideas...
    Black \'94 Trans Am A4- SLP CAI & Loudmouth<br />Red \'93 Firebird A4- Ram Air under the WS6 hood, !cat, exhaust.
      I have a 2000 3.8 Camaro and I made my own custom PVC intake. Directions: Take off the air silencer by unclamping the metal clamps from the throttle body coupler and the air box coupler now take out the air silencer and the throttle body coupler but leave in the air box coupler the one with the sensor pluged into it. Take a Female-Female Rubber PVC Coupler and a Male PVC Connector from Home Depot and slide the male pvc connector into the rubber pvc coupler (The rubber pvc coupler should have 2 clamps on it, be sure to slide the male pvc connector into the rubber pvc coupler and clamp it in)! Now clamp the rubber pvc coupler directly onto the throttle body and fit the stock air box coupler onto the male connector that is in the pvc rubber coupler and clamp it on. (The reason to use the male pvc connector is because the rubber pvc coupler is not quite long enough to go from the TB to the air box). Make sure all the clamps are tight. For added air flow unclamp the air box lid and take it out, take a pair of pliers and carefully snap out those air fins in the top of the lid and after they are out sand the surface flat and rinse it thoroughly then dry it good and clamp it back in. (Be sure to buy extra metal clamps)! Then finally buy a Frame Air Hog or a K&N air filter to top it off!
      This will make the motor sound much deeper kind of like a V8! Good Luck!!!
      2002 Z28 A4
      SLP Lid | TSP Rumbler | P&P Throttle Body | No Cats | 3.42s | M/T Drag Radials | No Front Sway Bar
      12.76 @ 108.42 w/ 1.90 60’
        I'm sorry a FRAM air hog. oops!
        2002 Z28 A4
          I REALLY hope this helps you Wraith2097, if you dont completely understand my insane directions try to search "pvc mod" or "home depot" in intake/exhaust. Again I hope this helps!!!
          2002 Z28 A4
            [IMG]C:\My Documents\pvc.jpg[/IMG]
            2002 Z28 A4
              Sorry I still dont understand how to link a picture. [img]graemlins/twak.gif[/img]
              2002 Z28 A4
                https://webmail.pas.earthlink.net/wa...&x=-1689598378
                2002 Z28 A4
                  Finally, here is my picture (look above)!!! :D
                  2002 Z28 A4
                    check it out. Just like L36 said, but with pics and stuff.
                    This mod works.
                    http://home.comcast.net/~grayman99/Air-intake.htm
                    01 Firebird A4 3.42
                    Powerdyne @ 6 PSI
                    and other mods
                      Thanks a ton guys, I'm gonna try to make it myself. I'm not exactly adept when it comes to making things from scratch but I'll make the attempt. If that doesn't work out I think I'll buy one of the kits shown on that link. The prices look very reasonable. Thank you greatly for the info.
                        be very carefull when you expose the MAFF screen on the front of the Throttle Body. Do not bend or even touch it. It is very frigile...don't even look at it sideways.
                        01 Firebird A4 3.42
                        Powerdyne @ 6 PSI
                        and other mods
                          Hehe I'll be really careful, only had my bird for two months. Don't want to mess it up.
                            6 days ago
