Cabin Air Filter? - FirebirdV6.com/CamaroV6.com Message Board
Cabin Air Filter?
  • Cabin Air Filter?
    Do the '98 3.8 Camaros have cabin air filters? I know some cars do and I hope mine does because every once in awhile my heater (or A/C) will throw a musty smell at me...
    No filters on our cars.
    Odor Correction
    Eliminating Air Conditioning Odor
    Odors may be emitted from the air conditioning system primarily at start up in hot, humid climates. The following conditions may cause the odor:
    Debris is present in the HVAC module.
    Microbial growth on the evaporator core.
    When the blower motor fan is turned on, the microbial growth may release an unpleasant musty odor into the passenger compartment.
    A service kit that can correct the condition is available through GMSPO to address this condition.
    To remove odors of this type, it is necessary to eliminate the mirocbial growth and prevent its recurrence. To accomplish this, these two procedures must be completed.
    Deodorize the evaporator core using Deodorizing Aerosol Kit P/N 12377951
    Install the new A/C Delayed Blower Control Package, P/N 12370470
    The blower control package will enable the blower to run at high speed for 5 minutes. It will do so approximately 50 minutes after the ignition has been turned off it the compressor had been engaged for 4 or more minutes prior to shutting off the engine. By doing so, the evaporator case and core are dried out, reducing the chances of a recurring A/C odor.
    Perform the following steps in order to deodorize the A/C system:
    </font><blockquote>code:</font><hr /><pre style="font-size:x-small; font-family: monospace;">1. Ensure that the plenum that draws outside air into the HVAC module is clear of all debris.
    2. Disable the A/C compressor clutch operation by disconnecting the clutch coil electrical connector.
    3. Dry the evaporator core by performing the following steps:
    A. Start the vehicle.
    B. Set the temperature control on maximum heat.
    C. Set the control to the MAX setting.
    D. Run the blower motor on high for 10 minutes.
    4. Locate an area in the air conditioning duct between the blower motor and the evaporator core downstream of the blower motor.
    5. Drill a 3.175 mm (0.125 in) hole where it will not interfere with, or damage the following components:
    The blower motor
    The evaporator core
    Any other operating part the of system
    6. Wear safety goggles and latex gloves in order to perform the following actions:
    A. Continue to operate the blower motor on high.
    B. Insert the extension tube of the deodorizer GM P/N 12377951 into the hole, past the mark on the extension tube.
    C. Use short spray bursts and vary the direction of spray for a 2-3 minute period of time, in order to dispense the contents of the can into the duct.
    7. Shut the engine OFF. Allow the vehicle to sit for 3-5 minutes.
    8. Seal the 3.175 mm (0.125 in) hole with body sealer or RTV gasket compound.
    9. Start the engine.
    10.Operate the blower motor on high for 15-20 minutes to dry.
    11.Reconnect the A/C compressor clutch coil electrical connector.
    12.Verify proper clutch operation </pre>
    [/quote]
    Matt
    1998 Mystic Teal Camaro M5
