MAFT or MAFT+ Difference?? Use? - FirebirdV6.com/CamaroV6.com Message Board
  • MAFT or MAFT+ Difference?? Use?
    I have a freind who will sell me his MAFT for a cheap price, and it says it can be used on 3.8L GN's... Now I looked online at some sites that sell these and for the 3.8L Camaros and firebirds its the MAFT+ that comes up. CAn I use the MAFT on my car? or is this incompatible with a 2001 Camaro? Thanks...
    You can use it. A search would probably help you out, but there are probably a million posts that would come up...
    The maft does mass air flow adjustments only.
    The maft+ also does ignition timing adjustments.
    Unless you have a way to monitor the car (like autotap, or a wideband sensor at a dyno), I would not recommend using either one though...
    If you run the car too lean, you can melt a hole in a piston. Too much timing, and you can break a piston skirt.
