Making S-pipe from U-bend - FirebirdV6.com/CamaroV6.com Message Board
  • Making S-pipe from U-bend
    I need to get a 2.5" S-pipe so I can connect my high-flow cat to the 2.5" Flowmaster cat-back.
    I am going to buy a U-bend from summit but what radius bend do I need?
    1996 Polo Green Metallic Camaro:<br />SLP CAI, Carsound/Magnaflow 3\" in/out cat, Flowmaster 2.5\" cat-back... sounds great
    measure your current s pipe outisde to outside then get a 180deg u-pipe with that dimension cut in half and you should be good to weld.
    255/50R16 Tires, Pioneer Deck, Pioneer 4 Way speakers, PPI Amps, JL subs, Spec Stage 3 Clutch, Optima Yellow Top
