Ok, I got a 3x3 cat, but it does'nt fit with my pacesetter headers. What do I need for it to connect?
Pacestetter and Magnaflow cat don't fit.
Could use a little more info, like what is the problem? "It doesn't fit" doesn't tell us the problem. ;)
And you might have to wait more than 40 minutes for an answer.Matt
1998 Mystic Teal Camaro M5
And you might have to wait more than 40 minutes for an answer.K&N FIPK, Pacesetter Headers, Carsound Highflow Cat, 3\" Magnaflow catback, 180 Thermostat, 8.5 MSD Wires, NGK Plugs, Chrome ZR1 Rims
Either the y-pipe or the cat should have a section that is smaller than the rest so that it'll slip over. If not, you'll have to take it to to an exhaust shop to have them rig it up.Matt
Either the y-pipe or the cat should have a section that is smaller than the rest so that it'll slip over. If not, you'll have to take it to to an exhaust shop to have them rig it up.K&N FIPK, Pacesetter Headers, Carsound Highflow Cat, 3\" Magnaflow catback, 180 Thermostat, 8.5 MSD Wires, NGK Plugs, Chrome ZR1 Rims
i ran into the same problem when i got mine. the seem to design it to fit over the factory y-pipe and the pacesetter y-pipe is designed to fit over the factory cat. doesnt work to well when used together but like mentioned above. getting it welded is a good idea anyways but i think if you tighten it down good enough, it should work for now if you get it expanded.
It also sounds like a girly man. It's because of the two leaks.. right?
Or maybe I was driving around with an open ypipe. Man I wish it soumded like that.K&N FIPK, Pacesetter Headers, Carsound Highflow Cat, 3\" Magnaflow catback, 180 Thermostat, 8.5 MSD Wires, NGK Plugs, Chrome ZR1 Rims
