Well my SES light keeps coming on....My high flow cat is prolly setting it off.....I know I could use a 02 sim but I have a wideband 02 sensor for the supercharger. does anyone have a clue what I could do to get rid of the SES?
02 question.....
You need an 02 Sim for the after-cat 02 sensor. I reccomend getting one from ZZperformance, I got mine for 30 dollars with quick shipping and no problems.
2000 Pewter Pontiac Transam 360rwhp, 370ftlbs
1998 Sport Gold Metallic Chevrolet Camaro *SOLD*
1974 Silver Chevrolet BIG BLOCK Corvette
well I ran into another problem.....I put the 02 sim on and it still is registering a bad 02 sensor. I was wondering 2 things I guess.....is there like 02 sensor I can buy that is better than the stock one? and if I put an 02 sensor in....does anyone know how far beyond the cat it needs to be?
Did you clear the code, or did you just plug it in and still have an SES light? It'll take a while for the code to go away by itself, even after you hook up the sensor. You should be able to unhook the battery for 30 minutes or so to clear the code right away.Matt
1998 Mystic Teal Camaro M5
Take it to autozone and have them clear it.
Or just drive around a few days. After a couple cycles it'll go away.Matt
only reason it'd still be on would be fer one of 2 reasons: bad sim or faulty wiring. grab a multi meter or even just a continuity tester and see if ur gettin current in there.2000 3.8L Camaro A4 Pewter Y87<br />K&N Filter, SLP Ram Air kit, Eibach Pro Kit, Flowmaster 80 series, Silverstars, NGK plugs and MSD Super Conductor Wires, Electric Water Pump
well I dont know if this would make a difference.....but when they installed my headers and stuff....they put the sim on the 02....but they did not put the 02 sensor back into the exhaust system....would that make a difference? because i thought that the 02 sensor had to sense a certain heat as well?
I don't think you understand the point of the sim. It's purpose is to simulate a working sensor. If you have the sim installed, you don't need the sensor any more. It could be sitting in the garbage for all the PCM cares. The PCM thinks the sensor is hooked up and working properly. It's not even physically possible to use a sim and sensor at the same time. You could install the sensor into the exhaust if you wanted, but it would just sit there without being plugged in...it wouldn't do anything.
Was the SES light initially off after installing the sim, or did it never turn off? If it's never turned off, get the code cleared. If it was off but came on after the sim was installed, it's because that sim may not work on the 00+, in which case you should've gotten the one from Caspers.Matt
Pre-cat sensors are different. They can't use a simulator, and must be installed in the exhaust. Are you saying that one of the sensors that go in the manifolds was not installed? That would cause a huge exhaust leak, as well as an SES light.Matt
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...7 hours ago
