Can home depot PVC withstand the heat of being right on throttle body? - FirebirdV6.com/CamaroV6.com Message Board
  • Can home depot PVC withstand the heat of being right on throttle body?
    I have a 98 and I am ghetto-rigging up an upper intercooler pipe, the angled throttle body is my vice.
    I am not sure how hot the throttle body gets but most PVC Black or White has a temp range of -10 to 180 Degrees........
    Hope that helps
    Eric
    Eric
    2005 Mustang 4.0
    1996 Camaro Conv
    2000 Ford Excursion
    "Darkness Falls"
      When I had a Home Depot lid, the PVC had no problems at all. After I replaced it with a Whisper Lid, I looked at it thoroughly and found that it appeared to be exactly like it was when I first put it on.
      Heck, even the paper bar code label was intact:
      http://www.angelfire.com/theforce/gl...eDepotLid.html
      Also, the PVC was not completely up against the throttle body. The rubber boot/connector section separated the PVC from the throttle body.
      As far as a 98, I've heard they present a special challenge because the throttle body is angled instead of being a straight shot as in 99+ 3.8's. Do a search in the forum and you'll find lots of entries related to 98's that should be helpful.
      I solemnly swear I am up to no good.
        Isn't the piece you are replacing already plastic anyway?
        1996 Camaro RS Bright Red<br />3.8L V6 A4 3.42\'s<br />K&N Filtercharger<br />Flowmaster 80 Series Muffler<br />Y87 Performance Package
            To keep the pvc from burning, get some header wrap, and wrap it around the section of pvc that is closest to the intake manifold. The header wrap will not burn through.
            -Marc
              I think I have an early 99 because mine is off center and slanted too.
              2001 Formula
                I'm not using it for cold air intake, it's for an upper intercooler pipe. In my situation the angled throttle body is probably better since it points downward and to the right direction where my pipe is coming from.
                [img]graemlins/burnout.gif[/img]
