Well,I bought 3 inch PVC Pipe and a K&N Cone...I can mount it pretty good but what do I do with the IAT? Can i just drill a hole somewhere between the filter and throttle body and stick the IAT in there and seal it up with silicon or something?
Homemade Cold Air (IAT Location?)
Yep, any of those will work, but you could also put a 15Kohm resister into the plug. It won't give you much more power but it won't throw any codes either. If you'd like more info do a search, I think most people call it the "resistor mod".
[ June 08, 2005, 06:59 PM: Message edited by: c-wood bird ]2002 Firebird. XM and subs. Tin-can Intake. 180 Therm. Fan Switch.<br />15Kohm Resistior Mod. Flowmaster 80.
http://www.camarov6.com/cgi-bin/ulti...=002786#000001
Here's a post on it.2002 Firebird. XM and subs. Tin-can Intake. 180 Therm. Fan Switch.<br />15Kohm Resistior Mod. Flowmaster 80.
you can also use a large fat grommet. perfect fit is a late model v8 fbody IAT grommet.
