While I don't have FI right now I plan to down the road. I want to know what would be the optimum setup for such. I would like input for both supercharger and turbo as they could/would be different. Performance is first, fitment second, and sound is third. Thanks in advance.
exhaust setup for forced induction
A true dual 2.5" system would be optimal for a 10psi or higher boosted V6. Everything else is less optimal regardless of size.2002 5-spd NBM Camaro
Details: www.1lev6.com
Single turbo would be 3" open downpipe, doesn't get any easier/cheaper than that.AIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
downpipes usually terminate at the cat, but xjarayax means just have a turbo w/ an open downpipe. depending how far you get into the engine, a 3" exhaust would be minimal, this equates out to a 2.25" true dual exhaust. dominic's 2.5" true dual would allow u hardly ne backpressure, and equates out to a single pipe exhaust being 3.5" i think. this would be great if u had cam/heads and everything else done also. they make exhaust's that big for 450 hp LS1's, so I think u'd be good w/ at least 3" and no bigger than maybe 3.5" or 3.75".2001 Arctic White Firebird<br />More mods than I\'m allowed to list!
