TB Spacer anyone? - FirebirdV6.com/CamaroV6.com Message Board
TB Spacer anyone?
  • TB Spacer anyone?
    My neighbor who works in a machine shop said he was willing to machine me TB spacers... Yes, that's right, REAL tb spacers, in anodized aluminum if you wish...
    I will probably make these only for the 3.8's
    cause that's what I have. (however, if there is high enough demand I could make another production...)
    It looks like on the 98+ cars that the coolant going into the TB enters and leaves through the gasket. If I can get anyone to verify this for me, I could work this into the design and this mod could be a TB spacer + coolant bypass.
    let me know.
    [ March 18, 2002: Message edited by: Jeff Pristelski ]</p>
    How much?
    Past Ride
    1995 Firebird A4 3.8 Turbocharged -- 12.50 at 108
    (If you dont know me, you haven't had a V6 long enough)
    Current Ride
    2006 Mitsubishi Evolution GSR
    www.myspace.com/shane1015
      HOW MUCH???HOW LONG TILL THERE READY??
      98 camaro 3.8 (THE PUNISHER)<p>JET STAGE II/B&M SHIFT PLUS/TAYLOR WIRES/SLP LOUDMOUTH w-3\" s- pipe/SLP CAI/SS MESH GRILLE/160 STAT/DERALE OIL COOLER<br />FLEXALITE TRANS COOLER/ 3.42-ZEXEL-TORSEN/KONIG MONSOON & KUHMO TIRES/MANUAL FAN SWITCH/1le sway bars & poly/KYB AGX SHOCKS/H&R SPRINGS/LS1 ALUMINUM DRIVE SHAFT/rk sport headers<p>WAITING FOR INSTALL:ssm heads,cam,3 angle valves/trans go shift kit
        Well the price depends on the number run. He was talking under $50. The one that I will initially have him machine will be a half inch. (as I don't have any information to go on to determine the best spacing...) And the first production run probably won't be anodized. He said anodizing will cost about $600 for up to 100 spacers. However it will also cost $600 to anodize just 1 spacer... (NOTE: this is only for one color...) So I will only be doing this if there is enough demand.
        -Jeff
          wait a minute...your telling me its gonna cost you 600$ to get 1 throttle body spacer thats only a 1/2 inch anodized? Or are you saying that its gonna cost 600 to anodize 100 just one color? please tell me i understood that wrong, Because i work in a machine shop and it only costed us 300$ to get 300 4X3 inch parts annodized red. it was only a Dollar a part plus tax. Id be interested but i think they could be made for less. Not trying to piss you off or anything im just curious.
          2001 Black S10 Xtreme 4.3L A4<br />*RedLineVSix*<br />\"Throwin sparks, draggin frame\"
            how much would it help?
            Past Ride
            Current Ride
              What do the spacers do?
              1994 black camaro 3.4l m5<br />18\" chrome rims 235/40r18<br />Shaved door handle\'s and emblems<br />wings west ground effects <br />harwood hood, custom interior
                I'm interested in one as well. I had one on my Bronco it seemed to help a bit. Also wouldn't 1 inch be a better starting point?
                [ March 18, 2002: Message edited by: GoodOneStu ]</p>
                2001 Pewter Camaro<br />Mods: \"Just intake and exhaust\"
                  Aluminum is going to conduct the heat, if its not an insulator I don't want it...
                  2002 5-spd NBM Camaro
                  Details: www.1lev6.com
                    <blockquote>quote:</font><hr>
                    your telling me its gonna cost you 600$ to get 1 throttle body spacer thats only a 1/2 inch anodized? Or are you saying that its gonna cost 600 to anodize 100 just one color? please tell me i understood that wrong, Because i work in a machine shop and it only costed us 300$ to get 300 4X3 inch parts annodized red. it was only a Dollar a part plus tax. Id be interested but i think they could be made for less. Not trying to piss you off or anything im just curious. <hr></blockquote>
                    It'll cost me $600 to get a lot of these anodized, which is up to 100 spacers. So if I anodize only one, it will cost me $600, but if I do 100 it will still only cost me $600.
                    If you know somewhere that'll do it cheaper, that's great... hook me up with that guy.
                      <blockquote>quote:</font><hr>Also wouldn't 1 inch be a better starting point? <hr></blockquote>
                      I was originally only going to make one, for myself. And I have a 98 which means I have to deal with gm's stupid intake (which puts the throttle body at a downward angle...) This means that every little bit I space this TB out, I'm also reducing my intake capabilities by sharpening the angle of incoming air.
                      I think you'd be correct in saying that about 99+ cars. (Assuming the throttle bodies on 99+ use the same gasket as the 98's.)
                        <blockquote>quote:</font><hr> Aluminum is going to conduct the heat, if its not an insulator I don't want it... <hr></blockquote>
                        Good point, however you're not even using the coolant bypass mod... so correct me if I am wrong but it wouldn't make a bit of difference if the TB is insulated from the intake manifold since hot coolant is being pump directly into your TB.
                          FYI, aluminum is a good heat conductor. So, you are pretty much doing it for the looks then? Cause with an aluminum spacer, the TB will remain nice and hot.
                          DEE
                          1997 GTP(13.3@104)-Sold<br />1999 Trans Am M6
                            I too am interested in this. Just let me know the cost first.
                            Whisper Lid, SLP CAI, KN Filter, 3\" HiFlo Carsound Cat, full 3\" mandrel-bent piping, Flowmaster 80s, Casper O2 Sim, BM Tranny Cooler, Vigilante 3300 Torque Converter, Corvette Servo, 3.42 gears, SLP take-off LSD, Manual Fan Switch, & 160 Thermostat.
                              How exactly wil this help performance? If it doesn't help performance, why do it? Will your guy do a spacer that will allow the attachment of a ls1 throttle body to a v6 manifold?
                              2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
