Removing the maf screen?? - FirebirdV6.com/CamaroV6.com Message Board
  • Removing the maf screen??
    Where is and how do I remove the maf screen from my stock air box?? And any opnions on the whisper lid?
    Thanks,
    Chris
    1999 Firebird <br />Y87 Performance Package<br /><br />Borla exhaust, 3\" Catco Cat and 3\" pipe throughout, RK Sport Headers, K&N air filter, SLP CAI, Whisper Lid, 36 lb Injectors, ATI 3.8 Intercooled Procharger Kit.
    It is in the front of the Throttle Body, and do a search before you think about removing, you might change your mind. Although 98-up do not have the same problems as pre 98's when removing it I think you will find it is something you do not want to do :D
    97 Red Firebird<br />Best N/A 1/4: 13.98<br />Best N/A MPH: 96.13<br />Best Nitrous 1/4: 12.49<br />Best Nitrous MPH: 108.53<p>2001 Pewter Camaro SS <br />GTP Stage II Heads, Pig Cam, Holley Intake, SLP Headers, SLP Lid, Vigalante 3600 Stall Converter, MagnaFlow Cat Back Exhaust, Duel Electric Cut-Outs<br />11.26@121
      yeah, I just did it..had a few problems, different people get different results..just make sure you save that screen when you remove it. I popped an SES light and had to reset the pcm.
      -base
      \'97 v6. based out. See sig.<br />\"I\'d rather be rich than stupid\"
        go ahead with it. It will help a lot with throttle response and give 5 rwhp and 10 rwtq on a stock v6. If done in conjunction with other intake/exhaust stuff, will improve the response of this tremendously.
        Shorten your sig dude.
        [ March 18, 2002: Message edited by: Patrick Javert ]</p>
        2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
          take off all the intake parts, and its right there in the throttle body. Youll see a screen, Have fun trying to get it out without breaking it. Try taking out that little C clip around it first, I still wasnt able to get it without cracking it though.
          <a href=\"http://bellsouthpwp.net/d/e/defrag/sig.jpg\" target=\"_blank\">1997 Firebird V6-Y87/W68</a>
            If you remove it when the throttle body and all are hot, the TB will be expanded and it will practically fall out into your hands when you remove the C-shaped Sping.
            2002 5-spd NBM Camaro
            Details: www.1lev6.com
              <blockquote>quote:</font><hr>Originally posted by SkyHawk:
              Thanks,
              Chris
              <hr></blockquote>
              Whisper Lid rules, buy one! There is nothing quite like it, its a serious performance modification.
                <blockquote>quote:</font><hr>Originally posted by TheCardinal:
                <hr></blockquote>
                Except the Volant intake. :D
                  There are two small holes in the "C Ring" that holds in the screen. Just kind of get a knife or fork or something sharp and pointy, and push the two together, the the ring comes out easily. Then just use that knife or whatever to edge out one side of the screen. I don't see how so many people break it getting it out.
                    <blockquote>quote:</font><hr>Originally posted by Scott Black:
                    <hr></blockquote>
                    The Volant is all about looks... No real preformance gain, except a lighter wallet.
                    http://seppo.hopto.org/
