I'm sure a lot of you have seen this mod..buying a little resistor and plugging it into your IAT sensor to make the pcm think it's running cooler..
my question is..what resistor should I buy for my 97 v6? There's a guide here: http://eric.virginia.com/install_uni...ricker_mod.htm
but is the resistance the same?? Has anyone done this? Thanks.
-base
\'97 v6. based out. See sig.<br />\"I\'d rather be rich than stupid\"
<blockquote>quote:</font><hr>Originally posted by TheCardinal: Isnt WOT when you want the extra power? Im not saying it isn't worthless, but I'm curious...<hr></blockquote>
Yes, but on a cold day you will lose power. If someone disables so many PCM inputs, you might as well put a carb on the engine.
[ March 18, 2002: Message edited by: FirebirdGT ]</p>
