Just clearned my throttle body... - FirebirdV6.com/CamaroV6.com Message Board
  • Just clearned my throttle body...
    I bought a can of CRC "Air-Intake Cleaner" at Pep Boys for around $10 and took off my MAF screen (very easy) and sprayed a good amount into the throttle body while the car was off. I didn't notice that much dirt coming out of the intake (I had it parked with my nose facing downward so the dirt and oil did not go into my intake). I told my brother to floor the pedal (car was still off) and I got a CD and a flashlight so I could see the butterfly inside the throttle body and I sprayed the cleaner directly onto the butterfly... good lord, that's when I saw the black mississippi run out of my car!
    After I let the firt run out of the throttle body for a little bit (2 min or so), I wiped the inside out with a paper towel and started my car up. I sprayed some more into the throttle body with the car on and had to give it gas with my right hand so the engine wouldn't choke.
    I just took a test drive and my throttle feels 2 times better! I can't believe it. I have never cleaned the throttle body (124k miles). Good things, good things.
    \'96 M5 Camaro White<br />Flowmaster Full Catback<br />SLP CAI<br />180* Thermo<br /><br />Stereo: H/U - Clarion DXZ725 <br />Alipne Type-R 6.5 Components (front), <br />Alpine Alpine SPS-1629S 6.5 <br />2 10\" JL 10w0<br /><br />\"One Love\" -Bob Marley
    124K !!!
    suppose to do it every like 20K miles lol
    www.turbov6camaro.com
    1997 3800 Series II Camaro
      Well, I have only owned the car for 40k miles... I don't know if the previous owner cleaned it our or not (probably not).
        i have never cleaned mine. something to think about :\
        2000 3.8 A4 Pewter Camaro
          it would be a good time for you to have atop engine clean done.
          1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> &lt;Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> &lt;Fbody Tech Articals
            What is that and how much am I looking at?
              generaly there are 2 kinds. injector flush and top engine flush. Top engine is done 1 of 2 ways. either a drip hooked up to the booster vac line and runs through the intake plenum or a pressurized nossle is hooked to the throttle body and sends cleaners through that way. Expect aprox 50 bucks for that. a really good injector clean will flush the injectors and let teh cleaner sit on the pistion tops and combustion chamber and then the motor is run on cleaner only. Expect 75-100 for that.
                I have heard about you can clean the throttle body, but It never can to my mind. I was thinking every 50k miles but since it was mentioned every 20k. I have 27k so I better get to it/ What company did you use
                  i wonder if i can use b12 to do that...i used it to clean off the front of it, but not with the car running. I wonder if it would hurt it while running.
                  2005 Ford Focus ZX3 SE D20 M5 - Modified ;) <a href=\"http://www.knightenmotorsports.com\" target=\"_blank\">http://www.knightenmotorsports.com</a> <br />[ U R L = h t t p : / / w w w . g e o c i t i e s . c o m / h e a r t l a n d _ h e a t _ v 6 ] Heartland Heat V6 [ / U R L ]
                    kinda like seafoam?????
                    96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />&gt;&gt;&gt;15.375 @ 89.27&lt;&lt;&lt;NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
                      I did mine a couple of months back at 145k lol. Although I didn't clean the back of the plate since I was by myself and it's got drive-by-wire.
                      There was a difference, though not a huge one.
                      When the weather clears up, I will do it again, but this time clean the back of it.
                      1999 Pewter Camaro M5<br />Y87 Performance Package, Sport Appearance Package, Diamond Clears<br />Factory SS Hood, Free Ram Air Mod, Whisper Lid w/ K&N Air Filter<br />CarSound Cat 94009, B&B Tri-Flo w/ Quad Tips<br />BMR SFC, BMR STB, KVR Blank Rotors, Hawk HPS Pads<br />Black Painted Calipers w/ CAMARO Decal, 245/50 Dunlop SP Sport 5000<br />20% Rear 35% Side Tint, Red Reflective Inlays, Invincishield<br /><b>Young girls avert their eyes, weak men tremble, Ford dealers faint.</b>
                        sea foam is basicly crap... It works somewhat but just as well as any solvent would when it is used in the mannor that it normaly is.. Flushes and top end cleans cost a lot. But there is a reason. Because they work.
                        • Manimal
                          Coil springs
                          by Manimal
                          4 days ago
                        • Manimal
                          Newby here
                          by Manimal
