flames from the tail pipe - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Two more thoughts.
    1. If you run a high overlap cam, you may still get enough unburnt fuel to pull it off.
    2. The spark plug needs more than 12v to get a good spark. Ideally you would put a cheap coil back there, and toggle it on and off when you want a spark.
    \'98 A4 Camaro v6-&gt;v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
    • #17
      Yea- I was gonna say- you definitely need a coil back there b4 the spark plug.
      Joe
      All gone :(<br />Best ET ever: 14.3 (I think)<br />----------------------------<br />Check out my site for exhaust clips, burnouts, and pictures, and the supercharger throttle body mod.<br /><a href=\"http://www.geocities.com/net_addict/index.html\" target=\"_blank\">Click on the Firebird</a>
      • #18
        <blockquote>quote:</font><hr>Originally posted by Skapimp:
        = AUTO-EXHAUST FLAME THROWER =
        FOR THIS ONE, ALL YOU NEED IS A CAR, A SPARKPLUG, IGNITION WIRE AND A SIMPLE
        TOGGLE SWITCH. INSTALL THE SPARK PLUG INTO THE LAST FOUR OR FIVE INCHES OF THE
        EXHAUST PIPE BY DRILLING A HOLE THAT THE PLUG CAN SCREW INTO EASILY. ATTACH
        THE WIRE (REGULAR INSULATED WIRE) TO ONE SIDE OF THE SWITCH, AND TO THE SPARK
        PLUG. THE OTHER SIDE OF THE SWITCH IS ATTACHED TO THE POSITIVE BATTERY
        TERMINAL. WITH THE CAR RUNNING, SIMPLY HIT THE SWITCH AND WATCH THE FLAMES!
        BE CAREFUL THAT NOBODY'S BEHIND YOU. THE FLAMES CAN SHOOT OUT TWENTY FEET.
        Got that off a "bomb making site" hahaha.. damn the internet
        <hr></blockquote>
        Doesn't work, the battery doesn't put enough voltage to spark well, coils put out voltage in the thousands... the easiest way is run a jumper wire from a coil terminal to a plug in the end of the exhaust, there are not many toggle switches that can handle that kind of power though... then you adjust your tps (adjust it so it thinks the throttle is open wider than it really is) to make the car run rich or just pull a plug wire to get lots of unburned gas in your exhaust... also your cat will absorb most of the unburned fuel, so you might want to gut it....
        99 3800 NBM Camaro - (Xcessive Xcelleration Racing Team)<br />Ram/Cold Air Induction (custom)<br />Modified 4l60e Valve Body<br />Z28 Catback<br />SS Hood <br />Modified 99 GM 3800II <br />JB Performance Engineering<br />jfbperformance@cox.net
        • #19
          I had a 69 baja bug that needed a valve adjustment.....I could rap it out in any gear and when I let off FLAMES BABY!!!! They didnt "shoot" out but it made a good show non-the less.
          I have made a lot of money in my life, most of which I spent on cars and women.<p>The rest I have blown.
          • #20
            you can always hire a gnome to sit in your exhaust and make a flame with a lighter ;)
            2002 Silver Metallic A4 Firebird - All Options
            Hotchkis STB, Custom Madrel Bent 3" Exhaust, Pacesetter Headers, Whisper Lid, FT Ram Air, K&N Air Filter, D2S HID, Baer Rotors, !EGR, !MAF, 10% tint, Parrot CK3300
            Your Mom or My Dad?
            • #21
              when i did this in my 65 buick i used a diesal glow plug for a more constant flame.
              99 firebird 3.8<br />ftra,custom made air box, pacesetter headers, 3500 pi vig verter 3.73lsd trans-go stage ii shift kit corvett servo flowmaster cat back dees tb spacer <p>_ ___soon___ _ <br />P&P heads 3 angle valve job and a nice cam to go with i
              • #22
                Here, try this.
                autoloc
                I dont know anything about this. I just found it. Figured you guys would like.
                :D
                Justin<br />1998 Camaro Z28 M6<br />1985 Pontiac Fiero M5<br />1999 Pontiac Firebird A4<br />AIM: FTBvideo<br />\"Music\'s what I need to keep my sanity!\" --S.A Martinez, 311
                • #23
                  <blockquote>quote:</font><hr>Originally posted by 96BeastV6:
                  I can throw flames from my tailpipes.. just ask the Velocity Six guys that were at the Feb meet. :D ;) <hr></blockquote>
                  i can most definately vouch , i was like
                  [img]graemlins/omg.gif[/img] [img]graemlins/omg.gif[/img] [img]graemlins/omg.gif[/img]
                  <a href=\"http://www.velocitysix.com/\" target=\"_blank\">Velocity Six Car Club</a><p>1999 Pontiac Firebird A4<br />15.384@87.13mph
