I appreciate I need to do some more fine adjustments, tightening up header bolts etc, but my Steering Column is rubbing on the front tube of the Drivers side header.
Is this just cos the headers need further tightening?
Originally posted by speedy-v6-camaro: Adjust the column by loosening the bolt on the knuckle and slide it forward and tighten...that will fix it.
I tried that, but the bottom half of that slide thing wouldn't budge. I just grinded the knuckle down as much as I could and just live with it rubbing against the header. :(
