I am about to order pacestter headers for my 3.8. I am getting a shop to install them. Do i need to buy an install kit or different gaskets?
Pacesetter install kit?
1996 Camaro -- SLP CAI, Motorvator TB spacer, MSD 8.5 mm wires, 180 thermostat, Pacesetter headers, Catco 3 in cat, TSP Rumbler, custom painted interior, 18x9.5 Z06 replica wheels, Nexen N3000 265/35r18 tires, - Best 1/4 mile 15.3@89mphTags: None
i dont believe so. you can buy different gaskets if you spring a leak in the ones you get
Should come with everything you need except something to seal the EGR lol.00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
Mine came with the gaskets and bolts, everything you need. If they don't have emissions testing in AL, you may consider having the EGR outlet on the header just welded closed to prevent leaks. That's what I ended up doing after trying to deal with the leak.Matt
1998 Mystic Teal Camaro M5
I am ordering the pacesetters off texas speed. Do they come with the bolts and gaskets or will i have to buy an install kit?1996 Camaro -- SLP CAI, Motorvator TB spacer, MSD 8.5 mm wires, 180 thermostat, Pacesetter headers, Catco 3 in cat, TSP Rumbler, custom painted interior, 18x9.5 Z06 replica wheels, Nexen N3000 265/35r18 tires, - Best 1/4 mile 15.3@89mph
headers come with gaskets and bolts, although pacesetter just had a huge GP go thru them and they are having troubles with the y pipe fitment, they might have a fix for that though, but it might take awhile to get your headers. Good luck, I hope they fixed the y pipe problem
Ok Pacesetter headers come with new bolts (header and ypipe), new gaskets, and thats all you need. The Egr is a unit that prevents ping at cruising conditions. To find where the leak is that I was talking about find the flexible metal hose that goes from your driver side manifold/header to the EGR unit. The leak occurs at the rubber piece were tubing meets the header. So far I haven't found a way of fixing it short of welding/jbing it in place lol.00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...18 hours ago
