Is the "dual exhaust" on the Y87 package the same piping size as the regular exhaust on the v6 f-body? (2.25 inch?)
y87 exhaust and regular v6 exhaust size
yes, the only difference is that the y87 exaust has 2 outlets instead of 11996 Y87 Camaro, 175.0 rwhp, 211.6 rwtq.....1/4 15.500@88.54 <----- Needs work!!<br />-CAI, Custom bent S-Pipe, LS1 I-Pipe, Flowmaster 80 series, !MAF, manual fan switch, relocated trunk pop switch, 180 degree t-stat, More to come!<br /> <a href=\"http://camaro.wbisolutions.com\" target=\"_blank\">http://camaro.wbisolutions.com</a> <p>WANTED!!! Naked and handcuffed!
<blockquote>quote:</font><hr>Originally posted by defrag:
right thats what I thought, and is the piping size 2.25 inch?<hr></blockquote>
YesRobert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Chevy doesn't list a power increase from the Y87 exhaust, and I think it's more cosmetic than functional. Just by virtue of the fact that it has two outlets rather than one, it should help a bit.
One thing you could look into, if you want, is getting ahold of an exhaust from a Z28/TA or SS/WS6.
Cale did that on his, and I will be doing it on mine. Cale said that it sounds really good, and that he got a boost in power from it.Wife and a dog, they both think they\'re Kujo.<br /> <br />1999 3.8 A4 Y87<br />Navy Blue Metallic<br />BFG G-Force KDWS 275/40/17s, <br />WS6 Wheels (17x9)<br />Phoenix Transmissions 2400 Stall Converter<br />FRA, Holley Powershot filter, Whisper Lid, Ported Throttlebody<br />2000 manifolds, Flowmaster, WS6 Tail Pipes, <br />MSD 8.5mm Wires, MSD Coils, Autolite plugs<br />Performance Cryogenics treated rotors<br />1LE Sway Bars and panhard rod, 1LE front springs w/SLP Bilsteins, stock rear springs w/ 3rd Gen Bilsteins, BMR STB, KBDD SFCs, 1LE rear lower control arms, 1LE front lower control arms<p>1968 Chevelle Malibu 327 TH350
<blockquote>quote:</font><hr>Originally posted by Guardsman:
Cale did that on his, and I will be doing it on mine. Cale said that it sounds really good, and that he got a boost in power from it.<hr></blockquote>
He got the whole cat back right? because just the muffler will not do much. It would be better to get the s pipe and the I-pipe from the ls1 and get the muffler and tips of your choice.1996 Y87 Camaro, 175.0 rwhp, 211.6 rwtq.....1/4 15.500@88.54 <----- Needs work!!<br />-CAI, Custom bent S-Pipe, LS1 I-Pipe, Flowmaster 80 series, !MAF, manual fan switch, relocated trunk pop switch, 180 degree t-stat, More to come!<br /> <a href=\"http://camaro.wbisolutions.com\" target=\"_blank\">http://camaro.wbisolutions.com</a> <p>WANTED!!! Naked and handcuffed!
I picked up a takeoff Z28 muffler and tips from SLP for $50, including shipping to Orlando. You could also get them from a junkyard.
http://www.nobispro.com/carpics/pics/backside.jpg
And no, you won't get any noticeable power increase from just a muffler. In fact, without a bigger intermediate pipe, a dual outlet muffler will actually DECREASE your power by a tiny amount, all other things being equal. Think about it...with a single outlet, the exhaust gasses go straignt into the muffler on one side and straight out the other. With dual outlets, half the gasses must bounce off the end, and fight their way back upstream to exit from the other end of the muffler.
But the difference is too small to notice, and dual outlets look WAY better than one.
So if you are going to get a Z or TA muffler at a boneyard, you might as well pick up the i-pipe at the same time (remember that 98+ V8's have dual cat setups, might have to futz with it to make it fit) or just have a muffler shop make you a bigger i-pipe, whatever size you want...I had my Z muffler installed and a 2.75" pipe custom made for $125.
Rik
Hey, are Y87 exhausts mandrel bent, or are they still crinked (or whatever the word is)--<b>David</b>--<br /><a href=\"http://bryant2.bryant.edu/~dsantore/index.htm\" target=\"_blank\">The <b>NEW</b> V6Bird Website!</a> <br /><a href=\"http://members.cardomain.com/thev6bird\" target=\"_blank\">Cardomain site</a><br />ΔX
the "dual exhaust" is really just a second pipe coming out of the side of the muffler. 1 inlet-2 outlets. so no i dont think youd need any kind of balancer<a href=\"http://bellsouthpwp.net/d/e/defrag/sig.jpg\" target=\"_blank\">1997 Firebird V6-Y87/W68</a>
Veesix, I'm getting the entire catbcak set-up. The guy I'm getting it from is replacing his with a Flowmater Catback.
V6Bird, the pipes are the non-Mandrel (crinked) bend.
Edge, you don't need a balancing pipe, because the exhaust comes off of the manifolds, and goes into a Y-pipe, then back through the cat, and to the muffler in a single pipe.Wife and a dog, they both think they\'re Kujo.<br /> <br />1999 3.8 A4 Y87<br />Navy Blue Metallic<br />BFG G-Force KDWS 275/40/17s, <br />WS6 Wheels (17x9)<br />Phoenix Transmissions 2400 Stall Converter<br />FRA, Holley Powershot filter, Whisper Lid, Ported Throttlebody<br />2000 manifolds, Flowmaster, WS6 Tail Pipes, <br />MSD 8.5mm Wires, MSD Coils, Autolite plugs<br />Performance Cryogenics treated rotors<br />1LE Sway Bars and panhard rod, 1LE front springs w/SLP Bilsteins, stock rear springs w/ 3rd Gen Bilsteins, BMR STB, KBDD SFCs, 1LE rear lower control arms, 1LE front lower control arms<p>1968 Chevelle Malibu 327 TH350
