I have a cutout by not sure if i should install it. Will it hurt flow when closed? Will it help when open in 1/4 mile? Will it sound like crap?? Thanks
Cutout............Yes or No??
Past Ride
1995 Firebird A4 3.8 Turbocharged -- 12.50 at 108
(If you dont know me, you haven't had a V6 long enough)
Current Ride
2006 Mitsubishi Evolution GSR
www.myspace.com/shane1015Tags: None
You'll like it. It may make you sound like a ricer at higher rpm's, but I don't know for sure. If you get it, leave it open allways.2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
I had a cut out on my car a while back. My experiense was it made me lose a lot of low end but helped on the high end. The reason I got a cut out was because I had a flowmaster muffler which I really didn't like. It is much better than a flowmaster(in my opinion).At least you get some sort of performance out of a cut out. I got really sick of the cut out(obnoxious and blattie) and decided to stop being a tight azz and bought a borla catback. I'm really happy with the sound and the performance. Therefore you should have cutout welded on and if you don't like it don't worry because it is cheap to install or just close back up. BTW, if you close it back up it won't affect your current set up. Also, I ain't capp'n on flowmasters but they just weren't me.Good Luck. ;)<b>Red 1999 Firebird M5</b><br />Whisper Lid,Borla Catback,K&N,Dual Friction Center Force Clutch,Hurst Shifter w/Lou\'s Short Stick,!FRA,Suncoast Ramair hood,160 Thermo,!maf,Chrome ZO6 Wheels, Painted Calipers, CIA Headers, Taylor Wires, NGK Spark Plugs, 3\" Catco, Jet Chip Stage II, BMR STB, LCA, PHR, SFC, Fan Switch, FTRA<br /><b>Old Dyno Numbers: 183 RWHP, 217 RWTRQ</b><br /><a href=\"http://community.webshots.com/user/redsixer\" target=\"_blank\">http://community.webshots.com/user/redsixer</a>
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...7 hours ago
