Header LEAK Solution!!!! - FirebirdV6.com/CamaroV6.com Message Board
  • Header LEAK Solution!!!!
    Hey guys! As you know I've posted about having exhaust leaks. I found it was in my passenger header towrards the back. Then one night on my way home the driver's side header gasket blew. So both sides weree leaking. Solution to the problem: I have CIA headers and their gaskets palin out suck. So i ordered a set of Pacesetters gaskets and put them on along with adding some strong copper silicon to seal teh gaskets on both sides. I also put new header bolts in as well as new collector gaskets by Mr.Gasket. Problem solved no leaks at all. Hope this helps some of u guys out.
    01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
    AR stage 3 heads/intakes to be installed
    www.cardomain.com/id/firehawknwv
    www.vaperz.com
    PEWTER MAFIA/ Kristen's "PEWTER MAFIA KING"
    glad it worked. im planning on getting new pacesetter gaskets this december and the copper stuff and replace the gaskets one there now when i do the rest of my exhaust.....again
    2000 3.8 A4 Pewter Camaro
