Ok I think I finally found the exhaust system I want to go with, its on the TSP website, the 3 inch mandrel bent x pipe with bullet mufflers. I need opinions on this please, it's somewhat expensive but not out of my price range. It's not stainless steel, which I'm kind of hesitant about, it's 3 inches on an x pipe so I'm wondering if that will be TOO much flow. Will I be able to get this put on my F body v6 at an exhaust shop? If I don't go with this then I'm probably going with the SLP loudmouth, so opinions would be greatly appreciated, thanks!
Texas Speed Mandrel X pipe
It'll take the exhaust shop a bit of work to make it fit, but I'd love to see it on a V6 car!! If I wasnt about to get married and had a little extra money laying around, I'd be all over it. And I agree, for the normal car without a healthy heads/cam setup and power adder, it might be a bit much flow. It could easily kill your low end power. I'd say go with the normal Rumbler setup.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
yeah, its just too much. Timbo has true duals and i think he is running only 2.25 or 2.5
please tell me you are kidding...
power adder = nitrous, turbo, supercharger
i dont feel like explaining a cam to you right now. i think with a twin turbo setup this would be optimal though, the turbos would add enough boost and backpressure to really take advantage of this.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...4 days ago
