I'm getting ready to buy a new exhaust for my car but I have no idea which one to get. I was originally looking at the SLP Loudmouth but I'm not sure if it would fit good where it's for an LS1. So then I started looking at Magnaflow and Flowmaster and now I have no idea, will someone please help me decide?????
Which Exhaust To Buy????
i've heard flowmaster doesn't sound too good at higher RMPs, and can also be kinda restrictive until you have complete exhaust work, from the headers on back. magnaflow i've heard is good, but i personally don't think it's loud enough (i like it loud). and the loudmouth will fit fine if you get the LT1 install kit. i was considering the loudmouth or magnaflow, but then i started looking into the TSP rumbler, which i think i'm going to get.1996 Pontiac <a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">Firebird</a> <br />Black, 3.8L A4
Whatever you do get a full catback system all at once. You will be much happier that way.98 Silver Camaro V6<br />15.238 @91.74 w/ 2.288 60\'<br />Mods: K&N, FTRA, Pacesetter Headers, Spec 3 Clutch, 160 Thermo, TSP Rumbler, 3\" Catco, Whisper Lid, 3.42\'s w/LSD, Aluminum DS, Man Fan Switch<br /><br /> <a href=\"http://www.cardomain
I went on Texas Speed and Performance and found that they make a True Dual exhaust, would it be better than any other exhaust, and how does it sound?Whisper Lid, K & N Filter, Glow Gauges, Alpine Type-R Subs, Subthump Box, Rockford Fosgate 501bd Amp
Magnaflow sounds pretty good, its not too loud but when you get on it it screams. A high flow cat also makes it sound a little better.1997 Camaro<br />17x9 Chrome SS wheels, SLP CAI, Magnaflow Catback,<br />High Flow Cat, Blacked out Lights, 20% tint, AUDIO: 1600W Kenwood eXcelon Amp, 12\" Kicker L7, 1 Farad Cap (Recently STOLEN),<br />H&R Springs and KYB AGX\'s,<br />Billet Grille
no you dont want the dual exhaust because it is dual 3" exhaust and you will lose all backpreasure causing you to loose your low end torque. however they do mike a really nice single 3" exhaust which flows very well and has less rasp than most performance exhausts i have heard. unless you put a power adder on at the same time dont get the true duals.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
I thought this "loss of low end torque" issue was solved LONG ago on these boards? It's been proven that you don't LOSE any kind of power by putting bigger pipes on your car, the powerband shifts upward so it might FEEL like you lost some low end but in fact you've only gained quite a bit of top end. If you dynoed your setup before and after putting on duals or a 3" system in general you'd see that the torque curve is much smoother and still higher than before. So don't be scared of a 3" setup, it's deeper and better flowing than the 2.5" setups a lot of people on these boards swear by, especially if you plan on swapping heads/cam or using a power adder down the road.2002 Black Firebird:<br />A4, Y87, W68, T-tops<br />Best NA ET: 15.16 @ 90<br /> <a href=\"http://members.cardomain.com/darksde02\" target=\"_blank\">http://members.cardomain.com/darksde02</a>
