When I first got the exhaust, everything was nice and tight and stayed (about 15 monthes ago). Now I have to tighten the flange before the muffler (the cut-out type thing) every week or it comes loose and rattles like a mug. Anyone else had this problem or know how to solve it?
Rob
<b>2002 Pewter v6 Camaro</b><br />T-tops, Auto, stock GFX<br />mods: SSRA, Whisper lid, K&N filter, Borla cat-back, Pioneer HU, RF 6.5\" speakers, billet grill, clear corners, red tubing under hood, black CAMARO fill-in\'s, QTEC, GM power antenna, fan switch
When I purchased my Borla (used), the threaded holes in the flange were broken. I use bolt/lock washer/lock nut combos to hold the two pieces together and have no problems with them coming apart. :D
Mine stayed tight for 2 years. Then I attempted to install an electronic cut-out and found the bolts in the threaded holes rusted and would not come apart.
Long story short. I had to drill out the bolts and installed bolt/lock washer/lock nut combos like Jason did. Eveything is still tight!
