Question about Pacesetter problems - FirebirdV6.com/CamaroV6.com Message Board
  • Question about Pacesetter problems
    I ordered my Pacesetter's around june 10th from texas speed. I am going to have a shop do mine but i was wondering if my set will have problems or not? Can someone give me a list of the problems that can be expected with them? Also will i need to use 2 gaskets on each header so they wont leak and if so where can i get the gaskets? Will i have to order them?
    1996 Camaro -- SLP CAI, Motorvator TB spacer, MSD 8.5 mm wires, 180 thermostat, Pacesetter headers, Catco 3 in cat, TSP Rumbler, custom painted interior, 18x9.5 Z06 replica wheels, Nexen N3000 265/35r18 tires, - Best 1/4 mile 15.3@89mph
    The gaskets should come with the headers. You will only need the 1 set that is sent you, they work fine.
    As for problems: the knuckle on the steering column will need to be shaved down a little due to rubbing on the headers, the y-pipe might need to be lengthened in order to fit correctly over both headers, and you might have some contact between the y-pipe and tranny.
    You never know until you try to put them on if you will have a problem with them or not. Some people got lucky and got ones that fit, others had a large gap. So good luck and enjoy.
    98 Silver Camaro V6<br />15.238 @91.74 w/ 2.288 60\'<br />Mods: K&N, FTRA, Pacesetter Headers, Spec 3 Clutch, 160 Thermo, TSP Rumbler, 3\" Catco, Whisper Lid, 3.42\'s w/LSD, Aluminum DS, Man Fan Switch<br /><br /> <a href=\"http://www.cardomain
      the gasket they give your r fine. i never had problems w/ my steering column, the EGR "hole" is too long, the y-pipe isnt long enough and i just bent mine to fit, and it might touch the tranny cause mine does and you will need new spark plug wires(90* boot) to fit.
      2000 3.8 A4 Pewter Camaro
        The gaskets that they come with are about the only decent thing. Those seem to have sealed fine with mine... I did soak them in water the night before however. The problems I encountered with my headers were:
        y-pipe did not line up with the headers
        y-pipe rubbed on a flange on the tranny
        headers rub on the steering linkage
        Hope you have a good shop.
