Although I am not a well-educated gear head, I would tend to disagree with the comment that wire temperature is a function of air velocity. Many people have removed their screens (including me)and if air volumetric flow was constant, the velocity would decrease (true). But the topic of cooling the wire is more dependent on heat transfer parameters, such as specific heat, mass flow, and enthlapy of the air. http://tech.firebirdv6.com/engine.html
So, if I made air intake mods to increase the volumetric flow, which assuming constant T&P increases the mass flow, and I removed my screen, I increased the total cooling capacity of the air stream. So, I guess the question is .. what really happened? and does it really matter?
And yes, it is very important to remember BOTH upstream and downstream straight run when dealing with any kind of flow measurement, and if it is supposedly 10 upstream diameters, than it is at least 5 downstream diameters. How does GM account for that?
