$695 of exhaust work... sound like a reasonable estimate?
that's not *too* bad.
that is quite a bit of labor, materials and welding.
you might see if you can find yourself a 2000+ pipe.
i can look around locally...maybe if you are able to spend a few days out of town while on break, dave or tracey (local f body gods) might be able to cut you a better price...shall i ask or no?
Sound like a lot of cost involved with labor, I wouldn't charge that much... You can probably find a used take-off Y and I-pipe from a Z28 or T/A at midas or something... if not free it should be cheap...
The look on their face when you tell them "it's only a v6" - Priceless
