$695 of exhaust work... sound like a reasonable estimate? - FirebirdV6.com/CamaroV6.com Message Board
  • $695 of exhaust work... sound like a reasonable estimate?
    Manifold remove/replace
    Custom Y-pipe
    "Hang the cat" - I hope he meant install it
    and pipework (with my pipes) from the cat to the muffler
    grand total: "about $695"
    But... the custom Y-pipe is $185. If I buy one from a 2000+ car, that'll knock a good chunk off.
    so I'm looking at probably over $500 of work... how does that sound?
    www.RedLineVSix.com || 1996 Camaro, 15.159@92.5mph
    that's not *too* bad.
    that is quite a bit of labor, materials and welding.
    you might see if you can find yourself a 2000+ pipe.
    i can look around locally...maybe if you are able to spend a few days out of town while on break, dave or tracey (local f body gods) might be able to cut you a better price...shall i ask or no?
    2011 Camaro LS 6M, in black.
      i paid just about 500$ for my catback + hi flow cat from the shop + installation of it all. so that sounds just about right...
      \'96 <b>Quasar Blue</b> Firebird A4<br /><a href=\"http://jamiethekiller@comcast.net\" target=\"_blank\"><i>jamiethekiller@comcast.net</i></a><br /><a href=\"http://www.woodlandrock.com\" target=\"_blank\">my band: woodland</a>
        That's cool, Drew, I'll grab ya on AIM to talk about that. ;)
        I have all the parts that they should need, assuming they can reuse my O2 sensors.
          Sound like a lot of cost involved with labor, I wouldn't charge that much... You can probably find a used take-off Y and I-pipe from a Z28 or T/A at midas or something... if not free it should be cheap...
          The look on their face when you tell them "it's only a v6" - Priceless
          99 3800 NBM Camaro - (Xcessive Xcelleration Racing Team)<br />Ram/Cold Air Induction (custom)<br />Modified 4l60e Valve Body<br />Z28 Catback<br />SS Hood <br />Modified 99 GM 3800II <br />JB Performance Engineering<br />jfbperformance@cox.net
            Y-pipe from Lt1/Ls1 won't fit. At least, that's what I've been told... I looked into it, 2000+ y-pipes are hard to come by.
            That's almost all labor cost, too... I have all the major parts.
            [ December 03, 2002: Message edited by: DrSquirts ]</p>
              if it's all labor, you're getting hosed.
