Pacesetters, 2.5"...what cat? - FirebirdV6.com/CamaroV6.com Message Board
  • Pacesetters, 2.5"...what cat?
    Like the subject says...
    I have the Flowmaster American Thunder cat back. I got some Pacesetter headers ordered. I'd like to replace my cat, but I'm not sure what to get.
    I believe the Pacesetters have a 3" exit. So I think that means I need a 3" cat. But how do I get a 3" cat hooked to my 2.5" cat-back?
    And also, I don't need a cat with an AIR tube, do I? Just the O2 bung?
    you can order a cat with a 3" inlet and a 2.5" outlet.
    95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------&gt; <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
      They have reducers to connect pipes like that. Example
      Regarding the sensor, you can just buy a seperate O2 bung that the shop can weld into the S-Pipe.
      You don't need the AIR pipe, but if you have it (like in Catco 6007), it just gets capped off.
      Matt
      1998 Mystic Teal Camaro M5
        where can i get a cat with a 3" in and a 2.5" out? i havent been able to find them anywhere.
        '99 Camaro Y87 M5 T-tops
        Flowmaster american thunder cat back, 2.5" magnaflow high flow cat, centerforce dual friction clutch
        Car Domain
          Yeah, I haven't been able to find one either. But I'd like to keep my options open for using 3" all the way possibly. I do have another question though:
          Do I use the pipe that goes between the cat-back and the cat? I'm talking about the one that makes two back to back 90* bends. It looks like it's only 2.25" piping.
            http://www.car-sound.com/catalog/universal/940.aspx
            Ive got that cat, first one on the page, 3in 3out, works fine, i had it welded to original s-pipe too before (the 90* bend pipe your talking about) i changed that out later. If it were me, i would just go ahead and flip out the stock s-pipe and put a 3" one in, but it is no necessary. you may throw a code too, but see first, and you can buy an O2 sim if you do.
            [ January 03, 2006, 01:17 PM: Message edited by: Harrison ]
            Black 1996 3.8 Firebird T5, SLP CAI, Pacesetter Ceramic Headers,160* t-stat, PCMforLess Tune, Flowmaster American Thunder catback, Car Sounds Cat, custom s-pipe, MSD coils and wires, NGK plugs, 3.42 posi rear, B&M Ripper, 245/50 BFG-G-force's
